This is a modified PiPlane originally done by SR71fan as an 18" plane.
I have had so much fun with this one that I decided it was time to scale it up.
The circle is cut from 9mm Depron. The top fuse is 6mm and the bottom is two laminated 6mm pieces to give it a total thickness of 12mm.
I hope you enjoy it as much as I have...
Posts
