1.5M yak 54
Discussion in 'Single Wing Aircraft Plans' started by tsknutsen, Feb 2, 2011.
  1. tsknutsen
    tsknutsen Member
    Ok i took some plans for yak54 and edited them to fit my needs,
    Im cutting this out of 3mm grey depron, which i sandwich and put 3x3mm carbon tubes from hobbycity inside for stiffness.. and then i've made pockets to fit in the rudders, Im currently in the process of cutting it and building it, with aim to have it finished by sunday. after sunday i will post a video of it, and youll know if its a total failure or just plain awesome :p, tho as its just a resize i guess itll work ok.
    the files are for 3mm depron cut with 1/16" bit
    Also thanks to the original plane designer for this awesome design of a plane that i've made like 5 of, i just edited this one to fit my needs :) Attached files yak 1,5m sheet1.cnc (154.5 KB)Â yak 1,5m sheet2.cnc (29.8 KB)Â yak 1,5m sheet3.cnc (30.2 KB)Â yak 1,5m sheet4.cnc (64.8 KB)Â yak 1,5m sheet5.cnc (5.6 KB)Â yak 1,5m sheet6.cnc (43.3 KB)Â yak 1,5m sheet7.cnc (22.9 KB)Â yak 1,5m.skp (2.1 MB)Â
  2. almostthere
    almostthere New Member
    Anna tx.
    awsome cant wait to see it
    Interesting. Look forward to seeing how this 60" foamy does.
  4. tsknutsen
    tsknutsen Member
    almost done building and it turned out way larger irl than i expected from the drawing. It got really massive wing surface, way more than my 1,5m balsa model yak. Allthough im hoping to have it flight ready in about 12.5 hours.
    Also hoping the motor i picked out for it is enough so that i can hover it :)
    LOL 60" for a foamy like that is huge. I bet it is pretty cool though.
  6. tsknutsen
    tsknutsen Member
    i tried it yesteday, as its only 3mm at the control surfaces i need to put in some carbon there, also it was a bit underpowered and kinda stalled out all the time. I made a video if theres interest, but im gonna put in a new motor and stiffen the controlsurfaces and then do some hovering and stuff to show off in another vid :)
  7. Evil-Tunes
  8. TigerPilot
    Where did you get these smilies, Glen?
  9. tsknutsen
    tsknutsen Member
    Video of maiden trip. The plane is a bit backheavy, really underpowered and some of the control surfaces need some carbon, look at the elevon.. I will however sometime after this sunday post a video of the plane having better motor and stiffer control surfaces.
    Yeah man!
    That is great. I love how big it is. A little tweaking and that thing is gonna be awesome!
  11. rcav8r
    That isn't all that flexible. There's a guy around where that I only see at the various fun flies. He has a plane similar to that but a little smaller. It flexes so much that when he does a roll the tail completes the roll a few seconds after the front of the plane. :D
    Neat how the wingtip bent without breaking at the end of the video... so flexible can be good :)
    Nice job! this is a real floater and would be a great practice plane for me indoors! I just have to build one :good:
