A.T.O.M. Project
Discussion in '* Scratch Built Section *' started by kram242, Dec 14, 2009.
    A.T.O.M. Stands for Aerial Tilt Object Motion
    This is a cool little project I have been working on that utilizes a gimble as a means for control.
    The idea here is to make a drone style aircraft that will be able to maneuver through tight spaces with accuracy and stability. The ATOM will also be able to compact flat to be brought out to the field for AP missions.
    Instead of using the typical 'flap' control surfaces of normal aircraft. The ATOM will use a counter rotating prop housed in a gimble system with gyros located on 2 axis.
    Right now the project is in the prototype stages and includes a stand for the study of the craft.
    Future versions will remove the stand creating a sphere object capable of 6 axis linear movements while in flight. Flying characteristics will be along the lines of a UFO and although it is housed as a sphere for the prototype this could be altered. There is potential for adapting to the toy industry for UFO toys and the like.
    I have to say that I am pretty excited about this project and look forward to seeing the results.
    I think that this could have the potential for making an impact on the way we look at controlled flight in the future.
    I would like to thank Blindflight for coming up with the ATOM acronym and for donating 2 gyros to the project! You rock Al :D
    More about Gimbels found here http://en.wikipedia.org/wiki/Gimbal
    Stay tuned for updates
    Short video of the first prototype in action
    Attached files [​IMG] [​IMG]
  2. Crash
    Mark, that thing is way cool! Imagine the possibilities with this kind of craft once the little bugs have been worked out. I'll certainly be watching your progress on this one!
  3. filthybeast
    filthybeast New Member
    Upper Lake Ca
    Its not easy to create something unique, that has not been done before. First the surfer dude, now the Atom which looks really cool, nice work! Whats next?
    And the wheels keep on turning!
    Awesome Mark.
    You never cease to amaze me with all the ideas you come up with.
  5. FozzyTheBear
    FozzyTheBear Member
    All I can say is, how do you find the time for this stuff!!!! Very cool design work.
    Best Regards,
    Julian (Fozzy The Bear)
  6. Flashsolutions
    Absolutely amazing! You must dream up this stuff in your sleep, otherwise I don't see how you would have time to come up with all this stuff! You are something else Mark!
  7. mavacpjm71
    mavacpjm71 New Member
    Mark, That is the most original new design I have seen in a long time. Get a Gyro on her....
    Way to go!!!
  8. iflyos
    iflyos Member
    Pfafftown, NC
    WOOHOO!! I LOVE IT!!!
    Man, Mark...you are truly an innovator!!!
    I need to win the lottery so I can afford more gear for all these designs!!
    Tim
    AG4RZ
  9. ewo
    Ha, I love it.
    I must have one :D
    :D Thanks guys! wow I am really excited about this one I think it just may work! :shock: :)
    This is what happens when you grow up without a TV in your house, you wonder about and question everything. One of the best decisions my Dad made for our family growing up.
    Thanks again
  11. 7up
    :shock: - :eek: - :shock: WOW!
    Just remember what I said about your brain going POW!
    :mrgreen:
  13. TigerPilot
    You are right, Mark. Two gyros will do wonder for this thing. How are you planing to control the 'z' axis rotation?
    Didn't I say Burt Rutan for the small stuff?? ;)
  14. kram242
    Thank you Kwok for the complement :)
    I was thinking that right now I was not going to control the z, but I thought since each motor for the counter rotating prop would have its own speed control. I could in theory slow on down and speed the other up and vise versa to get the z rotation needed?
    What do you think?
  15. kyyu
    You're welcome, I'll take credit. :p Ok, Marks probably need some rest. ;)
    I'm sitting here staring at a screen grab of the drawing. This one is very complicated. 1st thing I'm wondering is, do the servo's even work in the sphere config? I mean the structure is symmetric, so would the prop disks move or the outer sphere? Since the prop is a gyro, you would think the outer sphere would just do the rotating. :?:
    Here are the proposed movements of the ATOM.
    I think I know what you mean by which would move and from what I found is that as long as the main weight (batt) is on the outer ring that is what the outside ring servo (y) uses to push against. The inside servo(x) pushes against the the outside ring. With the first prototype I found that having the stand to push against with the prop wash column of air holding it in place was not enough to keep it from tilting the entire craft. So I moved the battery down to the lower main structure the support ring and that's what made the difference. This was not shown in the video. Once that was tested I knew there was a possibility of it working without tilting and without the need for the stand or fins.
    Kwok its all that gyro talk we had that got me thinking about this from the start :D
    p.s. one of the nice side effects of containing the battery in the lower section of the craft, is that it allows for a self righting ability to occur. This may require the outer ring to take on a slightly different shape to help in pushing into the right direction. Sort of the same concept of a weeble wobble :lol:
    I will work at that once I know that it is a project worth pursuing. The gyros should be here tomorrow!!!
    Thank you again AL
  17. kyyu
    Wow, wasn't expecting gyros so quick. Waiting to see what you are up to. I was expecting the gyros to be on the outside.
  18. kram242
    Kwok this is a total learning experience for me here with the gyros. I thought about what you said about them being on the outer ring and you are right that is where they should be. On the same platform as what you want to keep level. Makes sense.,
    Thank you for the tip
  19. 66tbird
    A couple of cheap HH gyros will fix that right up :p Nice design Mark, kind of begs to be a flying R2D2 in my eyes.
  20. kram242
    You know I picture this (if it works) as the ultimate drone for law enforcement and military. The control would be unlike any aircraft on the market today. I see the ability to move through tight area such as hallways in buildings and through windows with ease. It could be equipped with a light and a camera to send real time feeds back to the controller.
    I really think this type of flight has been only science fiction up to this point.
    We shall see how well the testing goes. But I may have to build a carbon fiber version and pose the question to the right people :)
    I am really putting some time into this project hoping that if it works out could be well worth it.
  21. rjarois
    mark, you don't have to worry about the war pigs of the world....the electronic stuff the military already have, we have no idea...they got so many secret weapons, more hi-tech stuff than we as civilians have knowledge of...they only let so much info out...man they made the GPS system for war many years ago...not for us to find our way around in our cars, lols. they prolly got fly sized weapons that can kill....man seems to have the military killing down very well....peace, randy.
  22. Evil-Tunes
  23. rjarois
    man, i wonder how many gyro's run that thing, i got ten bucks it don't even use them....prolly electronics that civilians don't even know about....man i do kinda like the way it lands, lols...
  24. iflyos
    iflyos Member
    Pfafftown, NC
    That thing is cool...wish we woulda had them when I was in the desert...I coulda slept a little better!
    Tim
    AG4RZ
  25. kram242
    I am hoping that the ATOM is able to fly exactly like this, without all the noise :)
    Randy, maybe instead of gyros it uses a 3 dimensional GPS system that is capable of pinpointing its position/orientation in space and any given time? With something like this you could cut down on weight and electrons and it could be controlled via satellite! I know if I had unlimited time and funds that's the way I would make it. :D
    Too cool guys
