Cutting depth
Discussion in 'Trouble Shooting - Support - Help Section' started by Keckhaus, Mar 2, 2012.
  1. Keckhaus
    Keckhaus New Member
    I download a BiPi cnc file from the forum, and this my first atempt at cutting a file. I used fanfold and it didn't cut all the way through. Since I am really new, what did I miss?? Ken
    Did you set your z axis zero to the surface of the foam before the cutting? You know how to do it?
  3. Keckhaus
    Keckhaus New Member
    Yoram,
    Thanks for the repsonse, what I did was set Z just below the top of the printer.
    But what I think you saying is to set the top of the bit on the top surface of the foam to be cut, is that correct of are you saying pllace the bit so that it touches the bottom of the piece being cut.
    Ken
    That is correct, Ken. The bit has to touch the foam and when it does you set the z axis to zero.
  5. Keckhaus
    Keckhaus New Member
    Yoram,
    Thnnk you, i will look forward to testing that tomorrow.
    By the way,have have you done anything to muffle the high rpm sound tht resinates from the enclosure?
    Ken
  6. 3DMON
