Drawing airfoils
Discussion in 'Sketchup Help' started by iflyos, May 29, 2009.
  1. iflyos
    iflyos Member
    Pfafftown, NC
    Ok..maybe I am a dummy, but I cannot figure this out for the life of me.
    Years ago, when I had GenericCadd where I used to work, I drew up some simple planes. The airfoils were flat bottom, and I used the arc tool to do the 'foil on the top. I seem to recall being able to grab the arc at any point, and stretch it to the shape I wanted.
    With Sketchup, all I can do is choose the endpoints, and stretch the midpoint of the arc...am I missing something?
    Any pointers would be appreciated!!!
    Tim
    AG4RZ
  2. rjarois
    Tim, i am not good at all in sketckup, but i do find a way to manage to draw what i need...the easiest way for me is to go to the airfoil page. http://www.ae.uiuc.edu/m-selig/ads/coord_database.html save the foil i want by clickin on the gif of it, then right click and save picture as a bitmap file. then import it into sketchup, make it super big, then just trace it with a series of lines. its simple, and it works for me. when your done just scale to suit your needs. randy.
  3. iflyos
    iflyos Member
    Pfafftown, NC
    Thanks, Randy! That will at least get me going on the plane I am working on! I appreciate it!
    Tim
    AG4RZ
  4. Evil-Tunes
    There are a few RB plugin files out there for different arc's I have one but not here I will have to look when I get home from work.
    Ok I found it. It's called "Bezier Splines" and here is a good page on it http://www.aecbytes.com/tipsandtricks/2 ... tchup.html
    Hope that is what your looking for. I have only used it a few times.
  5. 66tbird
    Bezier spline toolbar
    Complete set of polylines and splines curves commands: create, modify, convert. Cubic Bezier spline curve2, Uniform B-Spline, Polylines, modification of precision, add/delete control points, support of loop closing, conversion of any curve to spline curves
    Been the best tool yet for me and curves.
    http://xoomer.virgilio.it/kites/programmi/grafica/sketcplugins.html
    edit, I just read the thread again and totally missed the above post the first time :oops:
