flipped doesn't have cuts
Discussion in 'Sketchup Help' started by TigerPilot, Nov 17, 2011.
  1. TigerPilot
    shippo0708, if you look at the ear of the pig, the bottom one, there is a problem there. If you make the cut lines you'll see that the lines do not make a closed loop at that spot. I erased the line that goes up from the bottom ear and re-drew it and when I made the cut lines again it was a closed loop. For the PS to generate a code the outside and inside lines have to make a closed loop.
    Welcome to the forum, BTW!
