Found something interesting.
Discussion in 'General Phlatprinter 3 Chat' started by dhc8guru, Dec 7, 2011.
  1. dhc8guru
    dhc8guru Member
    San Antonio
    I was cutting some small one in circles in depron and noticed they started getting real egged shaped. Then I noticed my y axis return to zero went in the toilet. Started snooping around and found that a couple of the pressure roller lock collars had worked themselves loose. Well they weren't loose but I guess they had slowly backed away from the bushings after all the use. Anyways, readjusted the collars and problems went away.
    Good find dhc8guru thank you for posting this tip
