free depron....
Discussion in 'Foam Talk' started by rjarois, Jan 24, 2009.
  1. rjarois
    well not really free but cheap.....and it looks like depron, not sure if is is. went to the dollar store and picked up 8 sheets of what they call "foam board" it has one side with colored paper on it, and one side plain white. first you remove the colored side....best done by rolling it off.....then on the white side, soak with windex, wait about 3 mins. and it darn near slips off the foam. you end up with a 20in.x30in. 4.5mm thick of some nice flat phlatprinter food. oh yea, i paid $1.10 per sheet. once ya get the paper off its really lite, peace, randy.
    color side, roll paper off....
    tag....called readiboard...
    phlatprinter food....4.5mm thick
    Nice tip Randy
    thanks for posting
  3. rjarois
    thanks mark, did some research and found out this is depron. randy.
  4. bkboggy
    bkboggy New Member
    I get the same stuff, instead of Windex I used rubbing alcohol and it peeled right off... lots of bad smell though. I will try Windex, thanks. Have over 20 sheets of this stuff.
    -BK
