Homemade 5 Axis CNC
Discussion in 'General Talk Forum' started by NeilBlanchard, Apr 1, 2013.
  1. NeilBlanchard
    NeilBlanchard Member
    Maynard, MA, Eaarth
    NICE! this looks like a great project to build using OpenRail! :doubleup:
    Great find Neil thanks for sharing
  3. merkur23
    merkur23 Diy cnc operator
    Hedensted, Denmark
    I have a silly quest :)
    What about using a huge hotwire for the most of the Waste-foam ?
    Normally you would use a block of material 'close' to what size your final part would be. Then you would do a rough pass using a large bit to remove the bulk of material. Then go back with a fine tip bit to complete the final finish passes. So I suppose you could have a hotwire set up to cut the cut the block down to the rough pass size.
  5. NeilBlanchard
    Maynard, MA, Eaarth
    "Regular" density EPS can be recycled - there is a company called ReFoamIt that recompresses it into solid form. unfortunately for me, the high density XPS Dow makes cannot be recycled this way, as it can't be compressed with their machine.
