Lets Play name that plane!
Discussion in ''Aircraft KITS' you are working on' started by crash5050, Nov 2, 2010.
  1. crash5050
    crash5050 Member
    ALl right guys, I was digging around in the trailer the other day and decided it was time to get this bad boy out and see if I could get it running. This is the plane that took my finger off about a year ago. I removed the engine and shipped it back to SAITO, put new Hi-Tec servos in it, and ordered new wheels. The problem is that I cannot find this plane anywhere on the internet, and I need a canopy.
    If anybody has seen this kit anywhere, let me know, or if they know of a place where I can get a canopy made for t.
    David Attached files [​IMG] [​IMG] [​IMG]
  2. Anonymous
    What is the wingspan or fuselage length of that model, David?
    If you'll make and shape a balsa canopy, you (or someone you know) could form a plastic one from it, using their PhlatFormer. You'll need to add a "skirt" to the balsa plug, to simulate the fuselage top and sides, so the plastic canopy can be attached to the fuselage.
  3. Gefahren
    Gefahren Member
    is it about a .40 - .50 size? with about a 55" - 57" wing, and a fuselage about that same length?
  4. crash5050
    crash5050 Member
    60 inches from nose to tail, 73 inches wingspan....
  5. crash5050
    crash5050 Member
    I have a sheet of plastic, I might try and draw a canopy in sketchup, then cut it.
  6. almostthere
    almostthere New Member
    Anna tx.
