Mastercam and cnc software
Discussion in 'Planet - CNC USB Software' started by dhc8guru, Jul 24, 2011.
  1. dhc8guru
    dhc8guru Member
    San Antonio
    Will the CNC USB software read mastercam files. I have been teaching myself mastercam and haven't figured out how to export the files to a format the cnc software will read.
  3. dhc8guru
    dhc8guru Member
    San Antonio
    Last place I would have considered looking. Thanks!
  4. dhc8guru
    dhc8guru Member
    San Antonio
    I haven't had any luck. I followed the setting given in you link. When I try to open the mastercam file in the CNC software, it gives an error " error in G-code line 19 invalid charactor".
    I have tried different parts and all of them return the same error. I must be missing something.
  5. Kroko
    Kroko Member
    When I wanted to check, if default posprocessor in Mastercam generates g-code which can be used wit controller, I found out, that it works if I disable cycles.
    I don't have any experiance with Mastercam and I'm sure there are other (better) solutions.
    Can you send me g-code to email so I can check it.
    Regards
    Andrej
  6. dhc8guru
    dhc8guru Member
    San Antonio
    Yep, I will email you the code tonite . I looked at the code in the editor and nothing looked out of the ordinary. Thanks! I am using mastercam X4.
  7. dhc8guru
    dhc8guru Member
    San Antonio
    So I figured it out. I wasn't posting the toolpath to an .NC file. I was trying to get the CNC-USB software to read a direct .MCX (Mastercam file). All works fine now. I am still learning mastercam.
    Also when you set up mastercam, make sure it is the default mill. Don't use a router, because it uses an N-code on output.
