milFlatEdge error
Discussion in 'SketchUcam Help' started by Anonymous, Apr 12, 2009.
  1. Anonymous
    I got this error message when generating G-code for my butterflies.
    What does it mean? What can I or should I do to fix it?
    (I don't speak geek very fluently.) Attached files [​IMG]
  2. Flashsolutions
    I got the same error on one of my files. It was a fold line that caused my error. I changed it to a center cut to get around it.
    If you find the same thing, we need to let Pete know.
  3. Flashsolutions
    Apparently it is a grouping that is causing the problem. Try exploding your parts and see if you still have a second grouping of the cut path under them.
    I had to regroup my parts. Not sure how it got double grouped to begin with.
  4. Anonymous
    Thanks for the clues Flash, I'll check the skp file when I get home. :)
  5. Jnida63
    Well, this error is really starting to annoy me, is there any way to go back to the old Phlatscript?
    It happens with everything once i group them up.
    I can do without the V tabs seeing as i can't even cut anything now :(
  6. 3DMON
    If you still have the old scripts saved then yes you can reuse them. Just replace the new version with the old version.
    I've used the new script a few times. Once I had the error but it was something I did that caused it. Every other time it has worked perfect for me.
    If you'd like I can look at your file and see if anything sticks out at me for why it's causing you problems.
    If you need the old scripts I do have them too.
    Shaun
  7. Anonymous
    I have some very sharp internal corners that seemed to be causing the problem. I changed to a 1/16" bit and raduised ALL the internals to 0.100" radius. The next time I generated the gcode, no problem.
    So, why doesn't the program know how to deal with sharp corners? When I zoomed in on them (before changing to a radius) the cut-path was doing a "Y-Turn" in every corner - which could have never worked. It actually would have produced a negative-radius corner. Very weird.
  8. 3DMON
    Yeah that is how Sketchup deals with offsets and has nothing to do with the script.
  9. Flashsolutions
    What do you mean? How did you change the radius of ALL the internals? Explain. Is there an option in Sketchup or did you change your drawing?
    I encountered the same problem but had to jump thru hoops to solve it. I noticed that it was how sketchup processed offsets and ended up marking my existing curves as cut paths without accounting for the 1/16" bit in order to get around it.
  10. Jnida63
    Ok, blew out all the phlatcodes again and set it for a 1/8th inch bit then redid all the phlatcodes.
    It outputted everything fine this time, the 1/16 inch bit might be on the right track.
  11. gadman58
    gadman58 New Member
    Rio Rancho NM
    Flash
    I agree, Sketchup has a horrible time with offsets.
    Any two lines with an included angle of less than about 60 degrees will give you fits, and requires lots of editing to get around it.
    The file I have included has quite a bit of work to get it to this point and it still won't give a good toolpath (offset) with out a lot of trimming and deleting of lines in the toolpath.
    But the software is free so I guess we should expect some extra work.
    Glenn Attached files roadrunner.skp (423.7 KB)Â
  12. Flashsolutions
    A quick work around for something like this is to simply weld the outside lines and mark them as an outside cut path.
    Most likely a 1/16" offset is not going to make any difference anyway.
    I don't mind doing some editing, as you say, it is free software and given all that it does in combination with the great phlatscript coding, it is truely a bargain!
