I've wired in my Easy-CNC relay board today and it's working perfectly. I used 2 switched sockets (one for each relay) and spliced the power lead for the driver board psu into them. The Dremel is plugged into my 'Relay 1' socket and i'll probably plug a hood-light into 'Relay 2'. I mounted the psu at the same time, so everything is securely mounted under the shelf. I've now only got one plug coming out of the Phlatprinter which is linked to everything. The switches on each socket aren't really necessary, but they do allow me to manually kill the power to the outputs if I need to. I just need a 'light' button on the Phlat Screenset now Si. Attached files
