Need Help For this Setup
Discussion in 'General Phlatprinter Stuff' started by Navop, Sep 11, 2011.
  1. Navop
    Navop New Member
    St-Telesphore, Quebec, Canada
    I would like to know if I'm doing something wrong, because when I test me step motor the rpm is is almost nill.
    The setup is as follows:
    4 x Nema 23 Stepper Motor (57BYGH115-003)
    Step Angle: 1.8
    Voltage: 6.3VDC
    Current: 3A
    Number of Leading wires: 4
    Holding Torque: 425 oz-in
    http://www.wantmotor.com/ProductsView.a ... =75&sid=80
    4 x Step Motor Driver DQ542MA
    Driving: 2 phase, 4 phase motor
    Current: 4.2A
    Micro steps: 128
    http://www.wantmotor.com/ProductsView.a ... =75&sid=82
    2 x Power Supply 350W, 48VDC (S-350-48)
    http://www.wantmotor.com/ProductsView.a ... =75&sid=90
    The connections are as follows:
    Step Motor to Driver:
    Black Wire: A+
    Green Wire: A-
    Red Wire: B+
    Blue Wire: B-
    Driver to Power supply DC+ To DC+, DC- to DC-
    Driver to Planet-CNC 4 USB 4 Axis
    Driver has a jumper between DIR- and PUL-
    DIR- (PUL-) to GND on USB Board
    DIR+ (+5V) to S1 on USB Board
    PUL+ (+5V) to D1 on USB Board
    Included are picture Attached files [​IMG] [​IMG]
    Sounds like it may be a power supply problem I don't think its getting enough voltage.
    Typically, the larger the motor, the slower it's max usable rpm
    Not sure off all your switch settings on the driver, but I would check switch 4 from reading the pic that can cut your voltage in half or allow full voltage.
    Hope this helps
    Cool looking setup :good: good luck
