Pocket contour on outer side
Discussion in 'SketchUcam Help' started by risros, Nov 19, 2016.
  1. risros
    risros New Member
    SLOVENIA
    I'm trying to create a pocket, but the contour is always generated on the outer side of the face.
    On your help video, it generates correctly on the inner side.
    Is this a bug pr am I doing it wrong?
    BTW, noticed that outside and inside cut are also swapped. The outside cut makes the contour on the inner side and vice versa.
  2. risros
    risros New Member
    SLOVENIA
    Update: seems like a bug. Happens for smaller faces.
  3. TigerPilot
    Maybe you have the faces reversed? Try reversing them by right clicking on the face and choosing 'reverse face' or what ever it is called and report back here if it helped.
    swarfer and risros like this.
  4. risros
    risros New Member
    SLOVENIA
    Wow, that was it! I reversed the faces and it works now as it shuld. Many thanks!
  5. swarfer
    You want to watch some video?
    If you do, you will see that the 'blue' side is always up (-:
