Sharpie Attachment Idea
Discussion in 'Phlatprinter 3 Attachments' started by scraighamilton, Jan 7, 2011.
  1. scraighamilton
    scraighamilton Member
    Coeur d'Alene, ID
    This is an idea for a Sharpie attachment I had last night. Instead of trying to get the pen to slide up and down. We could put it in its own carriage and it could slide. The pen would stay solid and not wobble around. With the right bushings and bracing, maybe it could handle the waves in the fff.
    I don't have my Phlatprinter 3 yet to check the z axis movement, so the height of the pen is just a guess. The pen is drawn to scale.
    Tell me what you guys think.
  2. dugd1013
    dugd1013 Member
    Air Capital of Kansas
    I like your idea. looking at your model made me wonder how the weight of the assembly could be controlled to handle more coarse or uneven materials. I was tninking that the addition of low resistance compression springs riding above and below the upper portion of the pen carriage would limit/control the amount of contact point pressure and distance the pen could travel over uneven surfaces. This may yield a variable, yet reasonable amount contact point tension of the pen. The springs could be set up as a travel limiter as well. Lots of options!
  3. scraighamilton
    Coeur d'Alene, ID
    I have been working on this concept. I think it's working pretty well. I'll try to put a video of it drawing later.
    Looks fantastic Craig! Way to go :doubleup:
  5. ewo
    Ahhahaha
    No doubt about it ....... I gotta have this tool ! :good:
    Cant wait for the video ! :girl_cray2:
    Great Job Craig :doubleup:
  6. scraighamilton
    Coeur d'Alene, ID
    My ppp/// will be here soon. So I mounted the attachment to my home built router. I know it didn't go back to zero, but I was pushing it pretty hard to make the video short.
    My machine doesn't like to go over 60 ipm. Ya, there is no sound. I took the video with my phone.
  7. ewo
    Sweeet :p
    I cant wait for this one ! :dance:
  8. scraighamilton
    Coeur d'Alene, ID
    Here is the Sketchup File.
    I used 1/4x 3/8 brushing and 1/4 rod for the slides
    The carriage MUST slide very freely. So that the weight of itself keeps it down. I tried springs but it well just dent the foam and dig in. You may need to polish the tar out of the rods. To install the pen, just push it in and slide up till tight.
    Please check out the tabbing before cutting. Attached files Sharpie Attachment Idea 7.skp (5.2 MB)Â [​IMG]
  9. ewo
    This is great , Thank you Craig :doubleup:
    Im cutting this puppy out right now :dance3:
    But where to get the bushings ? :twitch:
  10. scraighamilton
    Coeur d'Alene, ID
    Bruce, I got them at my local Ace hardware. They do have them at Lowes.
  11. ewo
    Little picture of what i have.........
    I think this will work just fine. I will pick up the bushings and the rods tomorrow
    Thanks for this cool attachment Attached files [​IMG]
  12. scraighamilton
    Coeur d'Alene, ID
    That looks great Bruce. Your mounting plate is upside down. :D
  13. ewo
    No problem. I will just turn the sharpie the other direction :p
  14. scraighamilton
    Coeur d'Alene, ID
    I guess I forgot to mention that on the slots that hold the sharpie, the bottom is bigger then the top. just turn the whole carriage around. I need to make a note on the plans. Sorry. :oops: :nervous:
  15. ewo
    It was easy to see the difference ! Its no biggie i just threw this togeather for a picture :D
    Nice work Boyz! this came out awesome looking :doubleup:
  17. ewo
    Being stuck at home today..... ICE'D IN ........
    I decided to rig my sharpie attachment so i could go ahead and experiment
    This is the result !
    I will have Video shortly . :fugly: Attached files [​IMG]
  18. ewo
    Here is a little vid . :dancepoint:
  19. scraighamilton
    Coeur d'Alene, ID
    Looks like it's working good. What did you use for bushings and rods?
  20. ewo
    An old antanai
    Its just to get by while im ICED in
    I will get the right bushings and rods when im able to leave the house :?
    It does have a little slop but not real bad.. And slick as glass
  21. ewo
    And the top sharpie point is definatly smaller than the lower.
    Dont let anyone pull your leg !
  22. crash5050
    crash5050 Member
    Any Chance that the sharpie attachment idea7.skp is off just a bit somewhere? I have cut 4 of them, and they are all 100% identical, but they will not fit into the keyway on the machine. it appears that the tabs are just a little bit offset inward.
    David
  23. scraighamilton
    Coeur d'Alene, ID
    David, that is the same file that Flash and ewo used, but I will double check just to make sure. :D
    OK David, you were right. I made some minor changes to the bottom tabs and slots. They where about .006" inward on both sides of Mark's original key-way drawing. I did update the file, so it should be a better fit. :oops:
  24. gben
    gben Member
    Southern California
    Craig,
    Thanks for posting this. I cut it out and assembled it this weekend. It has been fun using the PP3 as a plotter. It is working well. Good stuff.
    [​IMG] Attached files [​IMG] [​IMG] [​IMG]
  25. scraighamilton
    Coeur d'Alene, ID
    Ben, I am really happy that every thing worked out great and you are enjoying this attachment!
    BTW, your pp looks awesome! :doubleup: Love the paint.
