Sketchup to PDF
Discussion in 'Sketchup Help' started by Navop, Sep 5, 2009.
  1. Navop
    Navop New Member
    St-Telesphore, Quebec, Canada
    Ok followed the tutorial sketchup to pdf using cutepdf.
    I have a problem where 3dmon says to select cutepdf as output he mentiones that the scale should read
    In the printout 1 inches
    in Sketchup 1 inches
    I can't change the second line to 1
    Its the line found under Use model extents
    When I look at the pdf I only see one page i need 2 pages...
    Navop
    Hey Navop.
    Make sure you are in Parallel projection view instead of perspective view in the camera options.
    This should fix your problem. I forgot to metion that in the vid. oops.
  3. Navop
    Navop New Member
    than ks it worked
