STL Import/Export for Sketchup
Discussion in '3D Printer Software' started by kram242, Sep 1, 2012.
    STL IMPORT/EXPORT FOR SKETCHUP
    * STL4SU Here is an excellent STL Import/Export plugin for SketchUp written by Revar Desmera. You can find the import function in the File>Import Menu of SketchUp and the Export function can be found in the Tools>Export STL Menu.
    NOTE:This will both Import as well as export STL files.
    You can find more information about this plugin here:
    http://sourceforge.net/projects/stl4su/
    DOWNLOAD STL EXPORT/IMPORT Here:
    * JF_STL_IMPORT
    Jim Foltz has written and STL importer that seems to work a little better on complex STL files then the importer above.
    NOTE:
    However it only imports whereas the STL4SU above does both import and export. I have them both installed.
    http://sketchuptips.blogspot.com/2010/03/sketchup-stl-importer-redo.html
    DOWNLOAD STL IMPORT Here:
    To install this plugins just download the .rb files above and place then in your
    [pre]Program files>Google>Sketchup>Plugins[/pre] Folder
    Hope this is helpful
    Mark and Trish Attached files jf_stl_importer.rb (6.9 KB)Â stl4su.rb (8.9 KB)Â
