Trouble with reg Key and updated cnc software
Discussion in 'Planet - CNC USB Software' started by Starman, Jun 9, 2011.
  1. Starman
    Starman New Member
    Central California
    I have updated the cnc software and imported the settings. I can not get the activation key to work. Also with the updated software it will not accept the table gcode.I can jog and set P1 but not both P1 and P2. Any Ideas?
    David
  2. Starman
    Starman New Member
    Central California
    I figured out the gcode problem, I just used the open option rather then the load image option.
  3. Starman
    Starman New Member
    Central California
    I have gotten the success screen 3 times. However the next screen tells me it is a trial version limited to 25 lines. This is getting frustrating.
    Hi Starman,
    I think the reason we have not seen a response here is that these are strange errors you are getting.
    You may consider emailing or sending a PM to the creator of the cncusb software (Kroko) here on the Phlatforum, to see what he thinks it may be.
    Here is his profile link:
    memberlist.php?mode=viewprofile&u=2719
    I wish I could help more but I am not sure whats happening. Please keep us updated on the fix/outcome of your findings
  5. Starman
    Starman New Member
    Central California
    My machine is up and running. It was a case of the wrong key code to serial number.
    I successfully ran the table gcode minus the proper depth. This was without doing the complete calibration. Mark's new settings worked great. The only build problems I ran into was the long screws I think there are 15 or 16 of them were the wrong diameter. Went to the local box store to get some. The other issue was the ends of the roller bars must have expanded during the cutting process, as I had to file them in order to get the colletts on them. The rest of the build was smooth with excellent video build log instructions. It is a real pleasure to see this machine move on it's own. Now the fun begins.
    Thanks Mark & Trish for making this possible.
    David
    Good deal David! Glad to hear your up and running :good:
    Sorry about the serial number mixup :oops:
    Hope you have a lot of fun with your Phlatprinter :doubleup:
