USB to parallel?
Discussion in 'GENERAL Phlatprinter MKII Talk' started by rcflyboynj, May 9, 2010.
  1. rcflyboynj
    rcflyboynj Member
    Somewhere in Kansas.....
  2. Jnida63
    I doubt it, the power is different, just get a pci parallel card
  3. Anonymous
    What kind of a computer are you dealing with Nate? If it's a desktop you could buy one of those addon parallel-port cards (that plug onto the motherboard and adds a parallel-port connector out the back of the machine).
    If it's a laptop, you might get one of those PCMCIA adapter cards to work.
    Personally, I chose to buy a SmoothStepper card - http://www.warp9td.com/ - and connect my Dell Latitude via USB, because the built-in parallel-port was barely functional for a printer, but incapable of running the PP properly.
  4. Gefahren
    Gefahren Member
    Yea, if you have a desktop one of those parallel port add on cards would be the cheapest way to go. Try
    http://www.startech.com/category/parts/ ... /list.aspx
    The smoothstepper is certainly a good choice but you'll have to run Mach3 to use it.
    Some people have been using Linux and EMC. The smoothstepper doesn't work with those.
    The simple USB to Parallel adaptors loose all the critical signal timing that needs to be there to run the machine. So I don't know of any of those that will work at all.
  5. rcflyboynj
    rcflyboynj Member
    Thanks for all the replies!
    I am looking at a lap top (I don't know what brand or model I am still comparing prices) and will probably run Mach3, so I will probably go for the converter Dorsal mentioned. Thanks for the help.
    Does anyone use the converter and do you get good results?
    Thanks,
    Nate
  6. Gefahren
    Gefahren Member
    I have a Smoothstepper, but not a phlatprinter. It works great for me. I also think Mark has put a smoothstepper on his phlatprinter but I cannot be sure. and of course Dorsal said he had one on his machine.
