You can use the mult step in 3D cuts?
Discussion in 'SketchUcam Bugs' started by marcomartim, May 7, 2014.
  1. marcomartim
    marcomartim Member
    São Carlos - SP - Brasil
    I was doing some testing of 3D cutting
    One time I left marked to mult step
    The plugin failed, even clearing the mult step, I could not make cuts in 3D
    Installed over the new beta version, still the problem continued.
    the only way to make cutting in 3D, was to delete the files and reinstall
    after clean install, everything went back to normal, 3D cut works perfectly
    This was a bug?
    There is forecast to make cuts in mult step 3D?
    I have just tested my install of the beta3, and it works just fine. You must remember to restart Sketchup after the install.
    However, if you have a flat drawing as for normal Gcode generation, and tick '3D', the plugin will fail.
    3D mode only works on an actual 3D object, with its base on the XY plane, and no cutlines must be applied.
    Please note that the 3D cutting function is very rough and you should preview your Gcode in something like OpenSCAM before cutting actual material. A 3D cut can take hours.
  3. marcomartim
    marcomartim Member
    I understand the difficulties and the challenge of putting new features
    There is forecast to implement mult step in 3D?
    hugs
  4. swarfer
    multipass in 3D is already there!
    Note that the safe area must be at X0 Y0
    The 3D object must be at least 1 bit diameter from the bottom left corner of the safe area.
    See attached example display and the file that generated it.
    In a few hours 1.1e-beta4 will be available, please install it as it will contain a small bug fix in the 3D generator.
  5. marcomartim
    marcomartim Member
    Thank you for listening
    I would like to make 3D gcode with mult step of Figure
    But I can only generate 3D without mult step
  6. swarfer
    please please please give me the sketchup file, without it I cannot diagnose this problem
  7. marcomartim
    marcomartim Member
    Eureka! I discovered my mistake
    as always cut 1/4 plates "(6.35 mm) forgot to mark the correct thickness in the model
    Increased the number of details to force the test
    There was an error with the tool back into the material
    Attached, the Skp and gcode
    Thank you for listening and detachment.
  8. swarfer
    you need to move the part away from the origin. I moved it 5mm up and right and the code came out alright. changing to 25% stepover made it even better. here is a rendering from OpenSCAM for the code I generated.
  9. marcomartim
    marcomartim Member
    While generating the gcode correctly, this was not the result I wanted
    The square base, I did not want to cut, just cut the part profile
    I solved the problem by placing the settings a greater height than the model
    The piece has 30mm, 31mm configured with
    this solved partly because I needed take an extra step on the material (waste of time). put the gcode exited properly.
    Many pieces already have the lateriais the material in the correct measure
    Just need to cut the top
    result:
    Despite having to take an extra step
    I am very pleased with the result
    If encounter other difficulties, I report
    I hope this topic can help someone and show 3D capability
    congratulation, this wonderful plugin
    Thank you very much.
    hugs
