Z access interference
Discussion in 'GENERAL Phlatprinter MKII Talk' started by Ringo Davis, Mar 25, 2014.
  1. Ringo Davis
    Ringo Davis Member
    I bought a used MK2 and I'm trying to get it running. ! thing I noticed is that when the bit is raised to cutting height the Gantry (not sure of terminology here) hits the big drive roller. I attached a pic not sure if it is clear or not. It is almost touching in the pic. If I raise it anymore it rubs. So what happens is if I set Z to zero, then cut out even something small that takes about a minute, at the end the bit is too low at the end. It is hitting and missing steps.
    Is there adjustment somewhere that I'm missing?I guess I can sand the back of the gantry until it is clear but there must be something I can do or the previous owner could not have used it in this condition. It said for a couple years before I got it and then it was delivered by truck so I'm hoping something just got bumped along the way. Any thoughts would be appreciated.
    you are going to have to fix that (-:
    @kram242 is the one to ask though, he designed the machine
    That is a tight area for sure and it may be that the MDF is a little swollen or even that the face plate for the tool holder is sticking out a little. One other thing to try out is to make sure the bearings are seated on the rods for the Z this could cause it to be out a little as well. Other then that if the function of the Z is good an all is working I would sand it down if need be. Hope this helps.
  4. Ringo Davis
    Ringo Davis Member
    I did not think about it swelling, good point. The machine sat for a few years before I got it so that makes sense. I'll get to sanding.
  5. ewo
    Just a thought , I wonder if the tool can be raised in the holder??
    I don't own one , Just a thought
    kram242 likes this.
  6. ewo
    Just a thought , I wonder if the tool can be raised in the holder?? - Good thought Bruce maybe.
    In the pic above is the dust cover
