3D Help For Noob
Discussion in 'SketchUcam Help' started by noobsauce, Mar 7, 2016.
Tags:
  1. noobsauce
    noobsauce New Member
    USA
    I just downloaded Sketchucam because I was sick of Cambam, so I'ma little experienced in CAM software but I have no idea how to do this.
    I have a simple test file that I'm trying to carve out. Can anyone help a noob (hence the username) out?
    • test.skp
      File size:
      148.4 KB
      499
    The little help that there is reads:
    # Usage : Move Group or groups to within the safe area starting from 0,0 and on the 0 plane then run the contour script
    I find it works a little better if the bottom left corner of the part is not at 0,0, but rather a little more than bit diameter to the right and up.
    I tested it with a 6mm bit, and offset it 7mm. stepover% should be less than 50% otherwise the finish will be very rough.
    You also need to select the whole object and create a group.
    set Z zero at the top of the material, 61mm thick in this case.
    Results may not be what you expect, SketchUcam is focused on 2.5D work and the 3D module needs a lot of work.
    I believe a better solution is to design in Sketchup, export to STL file, import that into PyCAM and use that to generate the Gcode.
    settings I used
    SketchUcam is much better at 2.5D cuts, which are quite versatile (unless you want curved surfaces)
  3. noobsauce
    USA
    Alright I'll look into PyCam, and thanks for the help!
