68oz steppers $6.00 eBay
Discussion in 'MOTORS - Stepper Motors' started by dbtoutfit, Jan 29, 2011.
  1. dbtoutfit
    dbtoutfit New Member
    Alabama
    Hey guys,
    I found a deal I think is great on eBay, if you need 68oz steppers.
    I've been buying them for my projects.
    I have spoke with the owner, very good guy and real nice.
    He bought several 100 of these for a project that fell through, so when he's out of stock there gone.
    I am in no way affiliated with the owner, I just wanted to pass on a good deal for anyone looking for these steppers.
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190399534021&ssPageName=STRK:MEWNX:IT
    Hope this helps someone.
    Eric
    Good deal Eric thank you for sharing this :)
  3. kyyu
    Cool. Thanks Eric! :)
    It's a good deal if you buy four or so, since shipping for one is $11 and each additional is free. I wonder what I could do with these. What project can I make that will need low torque steppers. Any idea out there?
  5. scraighamilton
    scraighamilton Member
    Coeur d'Alene, ID
    cnc hotwire? maybe.
  6. 7up
    I thought this too, but since all my stepper motor experience comes from my Phlatprinter I'm not sure. Could someone confirm that these are stout enough for a CNC hotwire system?
    Buk I think they would work just fine, as long as your guide system is using a frictionless style bearing and not a slide bushing. The wire itself will have no real pressure against it, so it should be good.
    :02cents:
    I have seen guys using nema 17 for hotwires
  8. TigerPilot
    I posted in the past a site that shows how to make a hot wire foam cutter using drawer slider. The ones that are 100% opening have normally balls that they run on for almost no friction. I don't remember what stepper the guy used but I think they were higher than 68 oz/i.
    Nema 17 are usually in the 40oz range and to be honest I would go higher. I think you could get them to work but for a few dollars more you could get a nema 23 at close to 150 oz. That way you have no worries on the power to move the wire.
