F-16
Discussion in '* Scratch Built Section *' started by rescue911, Nov 29, 2012.
  1. rescue911
    This is the Combat Models F-16n that I am trying to finish.
    I want to convert it to EDF.If possible.This is going to be a long build.It is a big jet. Attached files [​IMG]
    Wow its a giant! What kind of EDF unit are you looking to put in here?
  3. rescue911
    I was told at our field that it would take a 90mm EDF.But he did not think the intake would be big enough for it to work.It takes a .40 to .46 nitro motor.I may substitute the nitro with an electric outrunner.This plane is set up as a pusher.
    I just got an email from a man named Will and he thinks he still has a canopy for it and maybe
    the retsacts.I still have the old ones but they leak air bad.
    Maybe with some cheater holes you could make it work? It's a very cool project
  5. TigerPilot
    Is this a foam plane?
  6. rescue911
    Yes it is Yoram.But it has a cloth covering on it.The other picture shows the compartment for the landing gear.It also shows you the plane is foam.
  7. TigerPilot
    Yeah, now I see it's foam. Judging by the last pic it looks like it will need lots of TLC to restore it, right? :)
  8. rescue911
    It is going to need a lot of it.
  9. rescue911
    The rear doors are repaired and hinged .The front door is ready to cover and primed.
    We can rebuild him, we have the technology! :good:
    Looking good Gary
