Lets add plywood parts here, by 66tbird
Discussion in '3D models' started by mrbubbs, Nov 20, 2009.
  1. mrbubbs
    mrbubbs New Member
    Kalamazoo, Michigan, US
    Post by 66tbird » Sat Nov 01, 2008 9:09 pm
    I just cut/paste from my RCG post.
    I'd like to add a pattern for cutting control horns from 1/16 ply. I use a 1/32 bit with dremal on high and the feedrate set to 20% of normal. Also I did like I've read before. I used a 1/16 shim after the big roller. Basically I lowered the 1/8" bit, laid down a sheet of stringy good for nothing balsa, moved the bit to were the start of the 12" wide ply was going to go, on'd the Dremal, raised and cut a channel. Then I removed the shim and changed the bit. After setting it all backup I set the bit level with the 1/16" sheet and did a tabbing test. Got my Z homed the second try and the job ran perfect.
    Works great, and I see no reason why 1/8 lite ply w1/16 bit would be an issue if you go slow.
    Attached files [​IMG] gcode_C_horns16.zip (10.4 KB)Â
  2. mrbubbs
    mrbubbs New Member
    Re: Lets add plywood parts here
    Post by 66tbird » Mon Nov 03, 2008 11:07 pm
    Here's another project I cut a built today using the 1/32 code. The thing works great. Flip the razor mounting ply for right or left hand pull. Or build two :) I have a YN that is helping me in my endeavors and his jaw hit the dirt when he saw how easy this thing beveled an edge.
    I have also created a code for 1/16 bit which I will run tomorrow.
    I found out after I designed the thing that there is one out there that can be purchased. Designed and built for the exact purpose. To bevel 6mm foam. A quick chat with my legal minded GF and a little research into the history of bevel cutting tools, which btw they almost all look the same, gives me comfort in posting this one.
    On a side note in the hobby cnc field there are a few simple, smaller, table movement type units that can be bought off eBay for about $500 complete after the current 'live.com' 25% discount. Those are perfect for ply (and many other materials) that the PP just can't do. For me I'm starting to see possibilities.
    Attached files bevel cutter 16.zip (7.6 KB)Â [​IMG] bevel cutter32.zip (20 KB)Â gcode_Bevel cutter16.zip (899 B)Â gcode_Bevel cutter32.zip (1.3 KB)Â
  3. mrbubbs
    mrbubbs New Member
    Post by 3DMON » Sat Nov 08, 2008 10:32 pm
    Here is another type of control horn.
    Code added is for a 1/16" bit with 1/16" ply.
    The SU file is plain so you can generate a different code from that if needed.
    I cut these at 30%.
    Attached files Angled Control Horns.zip (8.4 KB)Â [​IMG] Control horns 1-16ply.zip (1.1 KB)Â
  4. mrbubbs
    mrbubbs New Member
    Post by 66tbird » Wed Dec 17, 2008 8:08 pm
    I liked 3DMON's horn so I ran with it.
