Awesome job Igor! So glad to see you cutting and having fun Thank you for sharing this cool video with us. One tip I would make from watching the video is to rotate your tool path 90 degrees so that you are cutting along the Y axis instead of the X you will get better results in the over all cut Really cool Watt_the, with your building talent I can't wait to see what you are making soon. Mark and Trish
Thank you for this kind words. Actually I had them cut on the Y axis, exception being the motor dummy because the lines were good for the cylinders imitating the cooling fins. My problem for now is learning the way each mill bit works, and what CAM program is best for what I'm doing. Take care, Igor.
