New brushes
Discussion in 'General Talk Forum' started by kram242, Jan 20, 2009.
    Well my Dremel finally went out, so I bought some new brushes for her. Well see how it goes.
    Lowes for around 4 bucks Attached files [​IMG]
  2. rjarois
    mark, make sure that machine is tip top by april.....ya dont want pooping out on ya showing it off, lols, randy.
    TRUE!...I think I messed something up in the dremel because I was trying to 'dig out' the carbon pieces left in the shaft so I could put the new ones in and now its stopped again. So I need to take it out and give it a good cleaning and try again.
  4. Anonymous
    After "undercutting the armature" (now, doesn't that sound better, Mark?) you should probably burnish the armature with a piece of 300 grit wet-or-dry sandpaper to remove any burrs you might have created. They can cause a lot of problems until they are worn smooth.
    Yes, that means you will probably need to dis-assemble your Dremel again. ;)
    lol yes it does :)
    I was thinking that I would try and get away without going through all that trouble, but it looks like that is what must be done.
  6. blindflight
    Hummm, wonder if there is a "Brushless" Dremel type made.. BLING-BLING
    That would be nice!
