Newbie Needs Help . . .
Discussion in 'Sketchup Help' started by slowboy, Dec 16, 2009.
  1. Anonymous
    In Sketchup, click on "Help" (at the top of the screen) then "Welcome to Sketchup".
    Do you normally see that screen when Sketchup starts, or did you turn it off by un-selecting the "Always show on startup" box?
    I think, if the "Welcome" popup comes on, you will always start with a blank model.
  2. kyyu
    I have that "Welcome" popup turned off. And I always start up on whatever blank template is chosen in the preferences. Turned it on and still a blank template. Now if you saved you drawing as a template, then that would come back up at the beginning? But that would be the same drawing each time.
  3. Anonymous
    Kwok, I think you hit it! I'll bet he saved the drawing as a template, by accident. Genius! :)
    I would have to agree with you Dorsal I think Kwok solved this one.
    Nice going guys
  5. slowboy
    slowboy New Member
    Apparently guys, I must have saved something as template. How do I unsave as template?
  6. slowboy
    slowboy New Member
    Oh...when I go to templates in preferences, I have 3 that I want to delete.
  7. slowboy
    slowboy New Member
    never min last 2 posts
  8. slowboy
    slowboy New Member
    I've started a new project, but somehow I have given all parts a group number [1]. I've seen where I can explode parts, but not sure how to go about doing this. I need to renumber each part in parameter.
    Is there a video on how to renumber groups? If so, what is video called, and where is it?
    still a newby, but coming along
  9. 3DMON
    Right click on the group, select entity info. That is where you can change the name of the group.
  10. slowboy
    slowboy New Member
    Thanks Shaun...
    I finally got it figured out, I had to select all components in safe area and keep clicking explode until explode was no longer and option. Then, I had to select each individual component, and make each one a group in the order I wanted them cut.
    Keith
  11. 3DMON
    I just re-read your post...oops. I thought you were asking how to rename the groups.
    At least you know how to do that and you figured out how to do what you really wanted lol.
