Phlat Hingline tool
Discussion in 'SketchUcam 'Most wanted Feature'' started by crash5050, Jan 8, 2011.
  1. crash5050
    crash5050 Member
    How hard would it be to make a plugin that would create the hinglines for our control surfaces? 4 lines at depths to creat the fold. I know it is a pain sometimes to draw all of those little lines.
    Just a thought
    David
  2. 7up
    David, you can make one set of hinge lines, select them all and make a component of them, then right click on them and select "Save As" and save in your SU/Components folder.
    The next time you need a hinge line open your components window and drag it to your work area and scale, rotate, stretch it any way you need.
