Phlat Quake Sky Scraper Contest Show - 8/10/11
Discussion in 'PhlatLAB LIVE shows' started by theothers, Aug 10, 2011.
  1. theothers
    http://www.phlatboyz.com http://www.phlatforum.com We build a Phlat Earth Quake machine and cut out a sky scraper on the Phlatprinter 3. The idea behind this contest is to have you guyz build a platform that will absorb some of the impact of the "Phlat Earth Quake." We're still working on the details and the rulez for this contest but our example should be enough to get your creative juices flowing!
    We have the intro and then the show starts at about 1:45
    [pre] <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="480" height="296" id="utv587132" name="utv_n_739373"><param name="flashvars" value="loc=%2F&autoplay=false&vid=16564376&locale=en_US&hasticket=false&v3=1" /><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="src" value="http://www.ustream.tv/flash/viewer.swf" /><embed flashvars="loc=%2F&autoplay=false&vid=16564376&locale=en_US&hasticket=false&v3=1" width="480" height="296" allowfullscreen="true" allowscriptaccess="always" id="utv587132" name="utv_n_739373" src="http://www.ustream.tv/flash/viewer.swf" type="application/x-shockwave-flash" /></object> [/pre]
    Phlat Newz
    Phil14586 on YouTube cutting with his Phlatprinter 3
    Phil14586 with his Phlatprinter 3 Sharpie Attachment
    jovian - thank you so much for your 3D printer article at http://www.makingfoamfly.com Over to the left, you will see an article called Extrusion Vs Resin Systems. Check it out!
    jovian is working on Pocketing for SketchUcam!!!
    scraighamilton is taking on the Phlatprinter 3 hotwire attachment.
    As you know, he is the original designer of the Phlatprinter 3 Sharpie Attachment so we're excited to see what he comes up with. This is an old hot wire thread: http://phlatforum.com/viewtopic.php?f=270&t=2991&p=30077&hilit=hot+wire#p29976
    vicentel maidened his S.U.-37.
    You can check out the thread here: http://phlatforum.com/viewtopic.php?f=36&t=2868#p29114
    Sketchupyourspace
    http://www.sketchup-ur-space.com/competition/
    Model Aviation - Learn How to Design in CAD - Thank you for rcav8r for his efforts to have a Phlatprinter article published. Check out the modified final product in your latest issue of Model Aviation!
    Make Magazine! Make Magazine is considering reviewing the Phlatformer!!
    Buy your Phlatformer here: http://www.phlatboyz.com/Phlatformer_p_10.html
    CNC USB Controller MK2 Board
    You can win a planet-cnc 9 axix MK3 Board by participating in the Phlat Quake Sky Scraper Contest or you can buy your own at http://www.planet-cnc.com
    You can view the contest details here: http://phlatforum.com/viewtopic.php?f=156&t=3006&start=0 Attached files [​IMG] [​IMG]
  2. 7up
    Good show! Great contest idea! :doubleup:
    Thanks Buk I think this is going to be fun!
    Mark, what is this tape you've mentioned on the show and where did you get it? The one for the guides.
