Phlatscript Version 0.921 Chat
Discussion in 'SketchUcam DOWNLOAD' started by kram242, Sep 13, 2009.
  1. foamlvr
    foamlvr Member
    northwest Ohio
    I am currently using the Phlatscript version 0.918.
    I would like to upgrade to 0.921.
    I have forgotten the process of installing the Phlatscript.
    Do I need to uninstall anything ? If so what ?
    Where do I put the Phlatscript ?
    I'm using Su7 (free version)
    Thanks in advance
    Jeff
  2. kyyu
    There is a pdf help file in the phlatscript zip file that explains where to put everything. But v0.921 has the right folder structure, so you can just unzip the contents directly into your sketchup folder and overwrite the old files.
    Or you can use my dos batch files. I use them to quickly switch back and forth between the different versions:
    viewtopic.php?f=98&t=1103#p10111
  3. foamlvr
    foamlvr Member
    northwest Ohio
    Thanks Kwok
    Ok I have the new script in the Su7 folder. Now to overwrite do I just drop the new resources folder on top of the old one, and the new tools folder on top of the old one ?
    :oops: :oops: :oops:
    Jeff
  4. kyyu
    You're right. It makes a "PhlatScripT_v0921" folder. :? Guess the folder structure isn't right. Yes, just overwrite by moving the "resource" and "tools" folder into the main SU7 folder.
  5. foamlvr
    foamlvr Member
    northwest Ohio
    Ok got it, thanks
    Jeff
