(Text: Google translator) Because the file of this release is larger than the previous versions? After unpacking the folder "images" all the figures occupy 63.1 KB And a file that the "windows" is not listed, occupied alone 1.08 MB I copied all the pictures to a new folder "images" (98.1 KB), delete the old folder, the phlatscript worked perfectly. Grateful for the excellent plugin; hugs Marco. ==== (Texto original) Porque o arquivo dessa versão esta maior que as versões anteriores? Depois de descompactar , na pasta "images" todas as figuras ocupam 63.1 KB E um arquivo que o "windows" não listou, ocupou sozinho 1.08 MB. Copiei todas as figuras para uma nova pasta "images" (98.1 KB) , exclui a pasta antiga, o phlatscript funcionou perfeitamente. Grato pelo excelente plugin; abraços. Marco.
I've got a problem with the PhlatScript and maybe it's something wrong with my computer. When I try to set the parameters (whether using the button OR the menu method) I get the following error messages: then then if I click the "Yes" option AND after inputting the proper cutter, tab and safe zone dimensions, it doesn't seem to save the parameters at all. I've tried to click "OK" then exit and save Sketchup, then re-opening my file, I've tried a number of things, but clicking on "Parameters" gets me the same string of error messages. btw, When I generated a set of code, the "Comments" section of the file says this: (Generated by PhlatscripT {0.923}) (File: Skeleton-1.skp) (Bit diameter: 1.5) (Feed rate: 100) (Material Thickness: 2.88) (Material length: 3168.0 X width: 6048.0) (Overhead Gantry: false) (http://www.PhlatBoyz.com) All those dimensions are NOT what I input. As you may notice, I do NOT have Sketchup in the default location, but have installed it to my G: drive nearly 2 years ago. I have never had this issue until now, but I haven't run Sketchup for a few months, either. I'm running Sketchup 7, with WinXP Pro. So, What am I doing wrong? Or, How do I fix the problem? Attached files
Well, I don't know what the problem was, but I copied all the geometry in the goofy file and pasted it into a NEW file. After I resized everything back to normal, I tried the Parameters button and it works perfectly now. I also generated a new g-code file and it's perfectly fine also. Weird, but solved. :roll:
I've had something similar to that happen to me a while back. I don't remember what caused it, but I remember it was something I did that caused it. I can't replicate it now either to know what it was lol. Glad you got it fixed.
OK now can someone tell me where to get this It does not seam to be in the previous versions arcive !
Looks like Kwok added here bruce Thanks Kwok http://phlatforum.com/viewtopic.php?f=98&t=1110&start=0 Mark and Trish
