plastic film
Discussion in 'Foam Talk' started by swim93, Apr 17, 2010.
  1. swim93
    swim93 New Member
    anyone know a good easy clean way to get the plastic film off of the blue FFF?
    i need to peel it off two sheets cause i don't really want it on my next build.
  2. Flashsolutions
    I don't know of any easy way. It is a slow tedious process, best done after cutting the foam to shape.
    You have to get a start by using an Xacto knife to separate the film and then peal it away. The problem is the indentations which are pressed into the foam by the manufacturing process.
    Try pealing the film from different directions. Sometimes it peals more easily in one direction than another.
    Have never tried to steam the film to see if it might loosen it, but that might be worth a try.
    If anyone does come up with a good solution, I am sure we would all welcome hearing about it.
  3. kyyu
    Try a wood dowel or broom handle and roll the the film onto it. You will need to get a corner up 1st, to get it started.
  4. Jnida63
    I was thinking of building a hot wire slicer to cut down the 2 inch thick foam for stuff I don't want the plastic skin on, you could prob get tons of foam that way
  5. swim93
    swim93 New Member
    good ideas guys thank you.
    i am kind of reconsidering it now though cause i peeled it off of one side entirely and it really really cut down on the strength of the foam.
    i think i will try it anyways though.
  6. Anonymous
    I wonder if anyone has ever peeled an entire sheet and then weighed the ball of film they removed. I'll bet the total weight isn't more than 3 grams.
    I'm too lazy to do it myself - I just leave it on there because it does lend strength and rigidity to the foam.
    Your Opinion May Vary. ;)
    I have been using the floor underlayment and it has the skin on both sides. I love it, really makes for a tough airplane. Of course you could always add tape to both sides at key points to accomplish the same thing if not stronger.
  8. Anonymous
    "floor underlayment" ?? What's that and where did you get it?
  9. Jnida63
    I got some at ABC supply company once, it is really good stuff, some waves but not nearly as wavy as PBIII
    I got mine from a place called universal supply. They are a builders supply house.
    In construction I would shop there all the time, but I never knew that they sold fanfold. Evil-Tunes is the one who told me about them carrying fanfold. I have been going there and getting bundles ever since :D
  11. Anonymous
    Okay, but what is it? Is there a part number or brand name that I can look it up? A link, maybe?
    (I'm not in the construction trade, and the only "underlayment" I've ever seen is the soft foam/ sound buffer layer under the Pergo-type flooring.)
  13. dz1sfb
    dz1sfb Member
    Swim,
    Here is the method that I subscribe to. Works great, and I never have built a model with the film on with the exception of my first foray into foamies some 10 years ago.
    Ken :)
  14. kram242
    Great tip Ken thank you for sharing this, simple and quick :)
  15. 3DMON
    Wow!
    You made that look too easy. Great tip! Thanks!
  16. 7up
    That was pretty slick! :D
  17. Gefahren
    Gefahren Member
    Now that's the way to do it! I have never gotten the stuff to peel off like that. I was going to ask if people peel the foam before running it through there Phlatprinters or after since I never leave it on anything I build (or try to build). I'm gonna have to start practiceing that for my MKIII.
  18. Flashsolutions
    Amazing! Thanks for sharing Ken! I prefer skin off for painting and other issues. It has always been a pain getting the skin off and this will save a bunch of time!
  19. rcav8r
    Gee I gotta go try that now. I only have pink foam. Hope it's the same :)
  20. Anonymous
    WOW - If I'd known how to do it that easily, I'd have never cut a model with the film. Now, if we could just talk 3M into putting the printing on that side, it would ALL be good!
  21. blindflight
    That was like a magic show!! Very cool...
  22. rcav8r
    Forgot to post last night as I got caught up watching the teaser build of the MK3 off and on last night among other things. (My kids loved the cat in the build video BTW, they would keep going over to the PC to see what he was up to)
    Anyway on to the foam...I first tried this with a sheet of pink foam. Not sure if it was because it was my first try, or if it was that the pink is thicker than the blue, but I didn't get it off in one sheet. Sure was a LOT easier than the way I used to do it. One huge sheet of film, with a few smaller pieces. Even these smaller pieces were WAY bigger than my usual method.
    I then found an almost full sheet of blue. Came off just like in the video.
    Trick is ( as the pros know ;) ) is to get some bow in the foam while removing the film.
    GREAT method for sure.
