rhino head needed
Discussion in 'What plans are you looking for?' started by yotamkaufman, May 10, 2010.
  1. TigerPilot
    I tried it and it too doesn't give me anything. Might be some setting on my computer but I don't think that that is the problem. I still think that the problem is that the whole thing is a picture and not a vector image.But what do I know! :D
    The penguin file. Needs the pdf, on page 1, to go along with it. For 1/4" material. No Phlatlines.
    Attached files Penguin.skp (2.8 MB)Â
    Wow nice job Yoram! Did you do this one by tracing? It came out nice and clean
    Yap, I traced it.
    Nice work! :)
    Thank you for sharing this
  6. yotamkaufman
    yotamkaufman New Member
    perfect!!!!! can you please post dxf?
  7. yotamkaufman
    no worry, got it :p
    gonna' cut it soon, very soon... Attached files Penguin-1.dxf (1.7 MB)Â
  8. JamesRS
    JamesRS New Member
  9. navionflyer
    navionflyer New Member
    Richland, MI
    For raster to .dxf I use Wintopo http://www.wintopo.com/ It works pretty well, but you usually need to do quite a bit of clean up. Still, it's faster than tracing (at least in Autocad).
    Tim
  10. yotamkaufman
    this software is very useful. i used the "gamma" slider inside the image tab in order to make the lines darker. the results are pretty awesome.
  11. yotamkaufman
  12. yotamkaufman
    here is the "ibo" dxf. some clean up is still necessary.
    Attached files ibo145.dxf (442.7 KB)Â
  13. TigerPilot
    I downloaded the WinTopo program and tried it. I found that the end results needs just as much work, if not more, than just tracing it in SU. Don't know about AutoCAD.
  14. yotamkaufman
    the penguin (cell phone camera)!!! i made it from cardboard. about 30 cm high. needed some minor changes.
    does anyone working on any of the pdf files i posted? Attached files [​IMG]
  15. TigerPilot
    Yotam, was that made from the file I've posted?
  16. yotamkaufman
    not really :?
    I did it on my own. it still not perfect but it looks pretty good.
  17. yotamkaufman
    how's the cat going?
  18. Jnida63
    It's getting there, slow but sure. After the model is made then I have to tweak all the connection spots to get them right.
    There are 80 pieces to trace and tweak, it stinks but I am too far to quit now Attached files [​IMG]
  19. yotamkaufman
    looks like it's going to be mind blowing!
  20. kram242
    Looking good Jeff! It looks like your almost there.
  21. RobotHacker
    RobotHacker New Member
  22. RobotHacker
    Never mind. A quick Google search and I found more.
    Thanks,
    Aaron "Robot Hacker" Shaw
  23. 7up
    Here is the Rhino head done for 1/4" material. if anyone decides to apply the Phlatscript please post the code and I'll add it to this post.
    Attached files [​IMG] [​IMG] Rhino head rdy.skp (1.3 MB)Â
  24. TigerPilot
    Good idea, 7up, didn't think of it, to just take the head from the rhino post.
  25. yotamkaufman
    thank you!!! it's nice to meet good people that are willing to help with pure helping-cause.
