Tabs
Discussion in 'General Phlatprinter 3 Chat' started by dhc8guru, Jan 7, 2011.
  1. kyyu
  2. Kroko
    Kroko Member
    If you have drawn 3D object then answer in no. If you have drawn 3D toolpath then anwer is not in this version but it can be done if there in interest. Can you e-mail me your 3D dxf?
  3. kyyu
    I have a plugin that will draw the 3D tool path from a sketchup model. I also have a plugin that will generate the gcode from the tool path. So it's not critical. If the tool path can be imported into your software, than it will be a 2nd option. Here is a sample dxf file:
    Attached files [​IMG] test_3D tool path_inch.dxf (9.6 KB)Â
  4. Kroko
    Kroko Member
    I'll add this feature to my TODO list.
  5. kyyu
    Cool! Thanks!
