Toolbox organizer
Discussion in 'Functional Designs' started by Jnida63, Apr 15, 2012.
  1. Jnida63
    I got tired of my mobile tool cart at work letting my extensions and ratchets roll around whenever I move my cart from area to area so I came up with an organizer to hold everything in it's place.
    It is cut from the rubber floormats that Harbor Freight sells for $10 for 4 of them, they are a half inch thick and cut nicely on the PP.
    Here is the file if you want to adapt it to fit your toolbox, I will post a picture will all the tools in it after I get it to the shop tomorrow. Attached files [​IMG] toolcarttop.skp (531.3 KB)Â
  2. rcav8r
    Now that's a neat idea.... I have some of those mats. They work great on the ground to reduce fatigue when standing :D
  3. TigerPilot
    Neat idea. I like it. :doubleup:
  4. GorillaBob
    GorillaBob New Member
    Arizona
    That's thinking outside the box! I Like It!! :good:
    Very cool idea Jeff!
    Thank you for posting
  6. jonquinn
    jonquinn Member
    what kind of cutter did you use for that? did you have to stop to clean up melted foam rubber from the cutter?
  7. Jnida63
    used the regular 1/8 tilecut bit at 100ipm. I do use a harbor freight router speed control and had it set at the lowest speed i could get.
  8. thunder hawk
    Nice idea.
    Great job.
    George : :D
  9. Jnida63
    Here it is in my cart
