Using the X0 Y0 offset tool
Discussion in 'SketchUcam Tutorials' started by swarfer, Nov 3, 2015.
  1. swarfer
    Here is a video showing quick run through of using the X0 Y0 offset tool.
    This tool allows you to set the X0 Y0 point for the Gcode to somewhere other than the bottom left corner of the safe area. This offset is relative to the safe area, so if you move the safe area, the 0,0 point will move with it.
    @BobAd
