Why does the curvature instead of the corner?
Discussion in 'SketchUcam Bugs' started by Hadi, Mar 9, 2014.
  1. Hadi
    Hadi New Member
    Hi,
    When I try to cut the pieces by cnc router appears in some corners curvature instead of the corner .. What is the reason?
    A picture of the design and appears sharp angles, this is what I want to do
    But after the shear appears to me as the following picture
    Angles stocks as blue in the picture is required
    But red is not required and I want her to be like the corners of the blue ... what is the reason?
    Material: MDF
    Thickness: 19mm
    Router Bit: Plain - Dia: 6mm
    SketchUp 8
    Windows 7&8
    Thanks for the help
    Best Regards
    Hadi
    • P1.skp
      File size:
      108.7 KB
      264
  2. ewo
    Hi Hadi.
    I really have no idea ? I downloaded your skp file and converted it to version 7 and the cnc file generates
    correctly . I dont have the tools in skp 8 to to check anything. NO EXTENSIONS installed , i just use 8 to convert to skp 7 , Sorry.
    But im sure someone can help !
  3. Hadi
    Hadi New Member
    Bruce Thank you for your response to the topic
    Waiting for someone to solves the problem
    It's hard to understand you but it seems like your asking why there is a round corner where the red arrows are pointing? A round cutting bit cannot cut a square inside corner...
  5. swarfer
    a round toolbit cannot cut a square corner.
    you can create clearance in the corners by using the Phlatbones tools. you can read about them in the help, click the big blue question mark icon in the toolbar.
    What you need to do is use the Phlatbone tools
    I found these graphics helpful and I hope you do as well :)
